vikasveshan
HI All ,
I encountered one problem which m not able to analyze .The Problem goes like this :-
I am Monitoring some signal behaviour and
If i keep Probe of my Tektronix DSO ( DPO2024 ) connected between that signal & reference GND and then switch ON the Main Supply ,my system doesn't switches ON .
And as soon as i remove probe connection from reference ground ,System starts behaving normally . and if again i connect probe to reference ground ( With System in ON Working State ) then i dont face any abnormal behaviour .
In short if i switch ON my main Power supply and then connect probes to monitor required signal ,then there is no problem .
& if i switch ON the main power supply after keeping probes connected then there is a problem .
I would be very thankfull if anyone could guide me in understanding the cause of this misbehaviour .
Regards !!
V V
Regards !!
V V
