Help me design a burglar alarm that turns on after 3 wrong passwords inputted
expert
Member level 2
I WOULD LIKE TO DESIGN A BURGLAR ALARM FOR MY PROJECT
THE SPECIFICATION IS WHEN THE USER KEY-IN THE WRONG PASSWORD FOR 3 TIMES THEN THE ALARM WILL ALERT
IS THERE ANYONE HAVE AN IDEA TAT USE PIC16F877 TO COUNT FOR 3 TIMES ( USER KEY-IN WRONG PASSWORD) THEN GIVE A SIGNAL TO ALERT THE ALARM?
Re: BURGLAR ALARM
blueroomelectronics said:
What have you done so far?
so far i have design an infrared circuit by microcontroller PIC16F877
the circuit consists of a remote control to transmit data to the receiver side
then, the receiver receive data to check whether the key-in password is correct o not
if correct then it will give a sigal to magnetic lock, and the LCD will display "correct code" while if receive the wrong password then it will show "wrong code" and the magnetic lock remain lock
but i wish to enhance the security system of the design
then i wish to add a burglar alarm
the function of the alarm is to alert when the user key-in password wrongly more than 3 times
Re: BURGLAR ALARM
ur question is quite broad... Have u already got the key pad functioning properly? And what language are u programming in?
Re: BURGLAR ALARM
i 'm using ASM language to construct the design.
yeah, my keypad is function properly and the transmitter and receiver also work properly. But then i wish to enhance the design with adding an alarm. when ever the user key-in password wrongly more than 3 times then it will alert the alarm by microchip( PIC16F877)
but the main problem is i duno how to use ASM language to write the coding which able to count 3 times then output a signal to alarm circuit.
thxs for ur attention!!
Re: BURGLAR ALARM
You can try this ::
One thing you can do, count the continuous three wrong password entries if true then turn on alarm else wait for next entry.
In between if you will have right password entry then reset the counter for wrong password.
Re: BURGLAR ALARM
H_D_R said:
You can try this ::
yeah, this is wat i wan but i dunno which register or instruction can act like counter to count 3 times then alert the alarm..........can u give me some idea?
but anyway, thxs for the comment
Re: BURGLAR ALARM
You need to write some code that compares the user input with the pin. Each time user gets it wrong increment a counter. If user gets it right clear the counter. If the counter reaches 3 sound alarm and clear the counter. Sorry I dont know pic assembler but this should give you an idea
Re: BURGLAR ALARM
but is there anyone know the specific registers and the coding to write a increment counter?
Re: BURGLAR ALARM
Sorry have not used PIC. I don’t know PIC assembly.
Whatever is the processor but logic will be almost same. Let me try..
Do like this.
1.) Store 3 in any free register which is not used in your code or use PUSH and POP.(e.g. let’s say r1).
2.) Take one more register and store the number of trials here. (e.g. let’s say r2=0).
3.) Enter the password and Compare it.
4.) If it is true then no problem and reset the number of trials and reset the flag.
5.) But if it is false then flag should be set and number of trials increased by 1 and reset the flag.
6.) Compare r1=r2.
7.) If true then turn on alarm.
8.) Else go for next comparison (go to step 3).
Hope so it will help you..
Try it and reply the status.
Re: BURGLAR ALARM
Do like this.
6.) Compare r1=r2.
thxs for the ide, i will try it first!!!
Re: BURGLAR ALARM
Good, simple and efficient alarm.
in that ficheiro, it is the alarm, PCBs Hex. etc
Nick name: Alcindo
If they want a more compound has this here
Re: BURGLAR ALARM
I have two versions of the same alarm of the magazine enclosed EPE, I have PCB
Re: BURGLAR ALARM
Where is your souce code???? for this..... I mean asm file.......
