pankaj waghmare
Junior Member level 3
I am using a 8-bit binary signal as an input which is then mixed with the 8-bit pseudo random number by using an XOR gate then transmitted the mixed signal by using a wire link. To reproduce the original signal, another 8-bit pseudo random number (which must has the same sequence as used for transmitter) is XORed with the received signal. In order to extract the input signal from the received signal, the pseudo random number used at transmitter and receiver side must generate the same sequence, which requires the synchronisation. I am not using any modulation technique as I am only require to do a small practical and signal can be transmit by using a small wire.
I want to design the synchronisation circuit.How to implement that circuit? Could u please help me to implement this circuit.I dont know how to implement using PLL this circuit or using or DLL.Can somebody provide me the diagram for that for this project. I will be very much thanful.
Thanks
Pankaj.
Thanks
Pankaj.
