Help Identify the Chip
Tiwana6330
Member level 1
Hello Everyone
We have a OKI C711 printer attached to university network and almost every week, we change the toner cartridges. The old cartridges are a waste and are disposed off. However, recently I found these chips in the cartridges which look like RFID chips. Since I can get 4 of these chips every week, I think it will be useful if I can use these chips for various hobby projects. So I took one out today and put it in-front of my Lab RFID 13.56 Mhz card reader/ writer. However, it didn't recognize it. Can someone help me identify what this chip is? RFID? I want to erase the chip and save some data on it
Pic of Chip is attached
Cheers
Type:
Cartridge Chip
Place of Origin:
Guangdong China (Mainland)
is_customized:
Yes
Brand Name:
ACE-TECH
Model Number:
C710/711 EU
Very blurry picture so no part number visible, but looking at the spiral antenna it could be one of the lower frequency bands. A check for the resonant frequency of the antenna should identify it.
Keith
Keith
Very interesting. How can you check resonant frequency?
Since its part of printer, it should support both read and write operations. Therefore, it cannot be 125khz as they are write only. The other possibility is 13.56Mhz but my reader does not see it as a RFID tag (reader works fine with other tags)
Connect a signal generator through a resistor to the coil. Sweep the frequency while monitoring the signal on the coil. Not perfect but should get you in the right area. It could be 13.56MHz - you just aren't able to communicate with the correct protocol/modulation method.
Keith.
