help for double summation in Matlab
Ana-Maria
Member level 1
double summation
This a summation which represents the waves of a radio communication channel
Please give me the matlab code. I will donate 20 pts.
Thanks.
[/img]
summation in matlab
in fact i don't know this equation but u can try this
the double summation is exactly two "for loops" and their counters pass through the vector of T and gamma and taw
if this is not enough ,try to explain your equation more
matlab summation
Thanks.
[/img]
Here is the procedure what I'd follow
I define this equation for 'R' but for first for only one value of 'i' (i refers to the inner sum) and maybe call it 'Ri1'
then I would define this equation as a vector (hope you know what that is) for a vector value of 'i' from '0->I' as given in the attached equation. okay? and redefine the variable as 'RI', finally to get rid of the first summation, use 'sum' command i.e. sum(Ri)
I would follow the same procedure for the second (outer sum). I dont have too much time otherwise I would have tried to do it for you
__________________________________________________
groups.yahoo.com/group/telecom_research
    Ana-Maria
