help for bluetooth module
rajesh1987
Junior Member level 2
hi
i need to transmit data from PIC controller to moble using bluetooth. which module is cheap to use and easy to code . im using ccs compiler to write code for that. kindly suggest for me
regards.
HI
i have completed part of my project using ccs compiler that's the reason i need to write code using Bluetooth module. kindly suggest me
regards
hi
i dint got bluetooth module, i need to buy it, i need with low cost .i don't know how to write uart code using ccs compiler, if u got any uart code kindly post also suggest which module to buy..
regards
