library ieee; use ieee.std_logic_1164.all;
--use ieee.std_logic_arith.all;
--use ieee.std_logic_unsigned.all;
package mypackage is
constant s: natural := 4;
constant n_div_s: natural := 4;
constant n: natural := s * n_div_s;
constant B: natural := 10;
subtype digit is natural range 0 to B-1;
type digit_vector is array (natural range <>) of digit;
procedure dot_operation(g1, p1, g0, p0: in std_logic; signal gg, pp: out std_logic);
end mypackage;
package body mypackage is
procedure dot_operation(g1, p1, g0, p0: in std_logic; signal gg, pp: out std_logic) is
begin
gg <= g1 or (g0 and p1); pp <= p1 and p0;
end procedure;
end mypackage;
use work.mypackage.all;
entity carry is
port
(generalized_g, generalized_p: in std_logic_vector(s-2 downto 0);
c_in: in std_logic;
c_out: out std_logic_vector(s-1 downto 1)
end carry;
architecture circuit of carry is
begin
iterative_step: for i in 1 to s-1 generate
c_out(i) <= generalized_g(i-1) or (generalized_p(i-1) and c_in);
end generate;
end circuit;
entity dot is
port
(g, p: in std_logic_vector(s-1 downto 0);
generalized_g, generalized_p: out std_logic_vector(s-1 downto 0)
end dot;
architecture behavior of dot is
signal a, b: std_logic_vector(s-1 downto 0);
begin
a(0) <= g(0); b(0) <= p(0);
dot_operation(g(i), p(i), a(i-1), b(i-1), a(i), b(i));
end generate;
generalized_g <= a; generalized_p <= b;
end behavior;
entity cla_carry_chain is
port
(g, p: in std_logic_vector(n-1 downto 0);
c_in: in std_logic;
c_out: out std_logic_vector(n downto 0)
end cla_carry_chain;
architecture circuit of cla_carry_chain is
component dot
port
end component;
component carry
port
c_in: in std_logic;
end component;
signal q: std_logic_vector(n downto 0);
signal gg, pp: std_logic_vector(n-1 downto 0);
signal ggg, ppp, generalized_ggg, generalized_ppp: std_logic_vector(n_div_s-1 downto 0);
signal qqq: std_logic_vector(n_div_s downto 1);
begin
dot_iteration: for i in 0 to n_div_s-1 generate
dot_instantiation:
dot port map(g(i*s+s-1 downto i*s),p(i*s+s-1 downto i*s), gg(i*s+s-1 downto i*s),pp(i*s+s-1 downto i*s));
end generate;
input_connections: for i in 0 to n_div_s-1 generate ggg(i) <= gg(i*s+s-1); ppp(i) <= pp(i*s+s-1); end generate;
--(n_div_s)-bit carry chain:
generalized_ggg(0) <= ggg(0); generalized_ppp(0) <= ppp(0);
cla_carry_chain_description: for i in 1 to n_div_s-1 generate
qqq(i) <= generalized_ggg(i-1) or (generalized_ppp(i-1) and c_in);
dot_operation(ggg(i), ppp(i), generalized_ggg(i-1), generalized_ppp(i-1), generalized_ggg(i), generalized_ppp(i));
end generate;
qqq(n_div_s) <= generalized_ggg(n_div_s-1) or (generalized_ppp(n_div_s-1) and c_in);
output_connections: for i in 1 to s generate q(i*s) <= qqq(i); end generate;
q(0) <= c_in;
carry_iteration: for i in 0 to s-1 generate
carry_instantiation:
carry port map(gg(i*s+s-2 downto i*s), pp(i*s+s-2 downto i*s), q(i*s), q(i*s+s-1 downto i*s+1));
end generate;
output_carries_iteration: for i in 0 to s**2 generate c_out(i) <= q(i); end generate;
end circuit;
entity example11_7 is
port
(x, y: in digit_vector(n-1 downto 0);
c_in: in std_logic;
z: out digit_vector(n-1 downto 0);
end example11_7;
architecture circuit of example11_7 is
component cla_carry_chain
port
c_in: in std_logic;
end component;
signal p, g: std_logic_vector(n-1 downto 0);
begin
--q(0) <= c_in;
iterative_step: for i in 0 to n-1 generate
p(i) <= '1' when x(i) + y(i) = B-1 else '0';
g(i) <= '1' when x(i) + y(i) > B-1 else'0';
z(i) <= (x(i) + y(i) + conv_integer(q(i))) mod B;
end generate;
cla_carry_chain_instantiation: cla_carry_chain port map(g, p, c_in, q);
c_out <= q(n);
end circuit;
entity test_example11_7 is end test_example11_7;
architecture test of test_example11_7 is
component example11_7
port
c_in: in std_logic;
end component;
signal x, y: digit_vector(n-1 downto 0);
signal c_in: std_logic;
signal z: digit_vector(n-1 downto 0);
signal c_out: std_logic;
begin
device_under_test: example11_7 port map(x, y, c_in, z, c_out);
x <= (4,9,7,5,3,9,2,6,9,0,7,5,3,8,2,6), (4,9,7,5,3,9,2,6,9,0,7,5,3,8,2,6) after 10 ns;
y <= (0,9,2,4,6,1,7,3,0,9,3,4,6,1,7,3), (7,9,2,4,5,0,6,2,0,9,2,4,6,1,7,3) after 20 ns,
(7,4,9,3,4,6,9,7,6,6,5,8,2,4,1,1) after 30 ns;
c_in <= '0', '1' after 15 ns;
end test;
