Ashkar
Full Member level 2
I have designed an N-MOS H-Bridge using an IR2110 Gate drivers and IRF540N mosfet as shown.
What I need to know is that whether the waveform to start the H_Bridge is Right.
1) I have turned the High side mosfet on using 20 kHz 50% Waveform via IR2110 Gate driver and diagonal to the High Side MOSFET I have turned the Low Side Mosfet Using the Same PWM Signal of 20KHZ at 50% duty.
Please Suggest the Appropriate waveform for diving the System.
