H Bridge DC Motor Driver Circuit + PCB
Hesambook
Full Member level 2
An H-Bridge (Full-Bridge) driver is quite popular in driving loads such as brushed DC motors and it is widely used in robotics and industry. The main advantages of using an H-Bridge driver are: high efficiency, rotation direction change, and braking the motor. In this article/video, I have introduced a complete H-Bridge DC motor driver using four IR3205 power MOSFETs and two IR2104 MOSFET drivers. Theoretically, the above-mentioned MOSFET can handle currents up to 80A, however, in practice we can expect to get currents up to 40A if the MOSFET temperature is kept as low as possible, using a big heatsink or even a fan.
References
Article: http://bit.ly/2Z9GMgZ
[1]: IRF3205 Datasheet: http://www.irf.com/product-info/datasheets/data/irf3205.pdf
[2]: IR2104 Datasheet: http://www.infineon.com/dgdl/Infine...N.pdf?fileId=5546d462533600a4015355c7c1c31671
[3]: 1N5819 Datasheet: http://www.diodes.com/assets/Datasheets/ds23001.pdf
[4]: IR2104 Schematic Symbol, PCB Footprint, 3D Model: http://componentsearchengine.com/part-view/IR2104PBF/Infineon
[5]: IRF3205 Schematic Symbol, PCB Footprint, 3D Model: http://componentsearchengine.com/part-view/IRF3205ZPBF/Infineon
[6]: CAD Plugins: http://www.samacsys.com/library-loader-help
