movie_freak
Member level 5
at+creg command
I am using SIM300d GSM module.
Issue 1:
Are there any AT commands , which can be used to stop +CBM.
I get +CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
again and again..and the module hangs for some time during this..
It does it itself i.e. without sending the command AT+CSCB=...
So there must be a way for stopping this..
Issue 2:
My GSM module gets registered automatically with the network as soon as i turn the module on. Now after some duration if i don't have a signal the module gets de-registered. This is all fine.. Now if the signals are available again it does not register by itself with the network.
One possible solution could be whenever the module is de-registered with the network we can cut the power of the module and then restart it again..
But in this case how will i figure it out.. or know when the module is de-registered..
So is there any way of doing it.., if not then how will i figure out the de-registration process..
Many Thanks,
Surya
Issue 1:
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
+CBM: 6128,50,1,1,1
Issue 2:
Many Thanks,
Surya
