GPU vs FPGA - Performance and future utilisation - looking for discussion and opinion
watertreader
Full Member level 3
Just a opinion survey thrown to the floor.
FPGA has the advantage of parallelism and datastreaming under a lower clock speed(less power usage) while GPU have higher clockspeed and utilise float point calculation(better accuracy) though suffer from low throughput with memory access requirement and high power usage.
With the introduction of high level function language like OpenCL, CUDA, DirectCompute. Is there any shift in the balance towards more GPU usage? Since GPU performance often leads FPGA and CPU, would GPU usage increase? Would the GPU be utilised to share the workload of CPU in the future?
FPGA Versus GPU(GPGPU) as two ways of "Hardware Acceleration"
GPUs have a fixed computational/programming model
FPGAs do not, and their logic can be customized exactly for an application's needs.
FPGAs require (usually) some hardware design experience
GPUs does not
GPU is really a "software acceleration" that can accelerate certain class of compute-intensive applications. The only interface to the GPU (nVidia or AMD) is PCI Express.
FPGA, on the other hand, can be used for a broader range of accelerations. It has customizable IOs, so it can interface with any chip (with compatible signal levels, speed, number of IOs)
You can compare:
Xilinx highest-end FPGAs, XC6VLX760(~$20k) OR XC6VSX475T(~$10k)
Nvidia TESLA C2070 (~$3k) Or Tesla M2090(~$3k)
---------- Post added at 08:21 ---------- Previous post was at 07:37 ----------
You can look at this interesting discussion
GPUs VS FPGAs/DSP - NVIDIA Forums
