GPS signal level
john2053
I want to display the signal level of GPS data on the LCD.
If all the data is retrieving then the level indication on LCD will be high and 50% of data is retrieving and no data is retrieving then zero level indication. How can I achieve this?
The indication level as given picture:
we don´t know what
* GPS hardware
* microcontroller
* display
* programming language
* compiler
* hardware and programming skills
you have
so it´s rather difficult to find out what information you are looking for.
Please focus on one item and ask a detailled question.
Klaus
Adding to what Klaus said, you probably want to measure BER (Bit Error Rate) rather than signal level. GPS data comes from several satellites so using strength alone would require lots of graphs and be confusing to say the least. BER gives a better indication of how usable the data is instead of radio signal strength.
Brian.
Brian.
yeah, I want to indicate how accurately data is retrieving via bar graph and show that in the LCD. Actually measure the signal strength.
Hello!
You could consider retrieving the MSS frame which includes signal strength. But I don't understand this:
I may mean:
if (all the data is retrieving) {
level_indication_high
else if (50 % retrieving) { // Where would you put a 25% receiving for example?
else if (no data) {
NB: I think it would be better to operate in intervals, of example 0~20, 20~40, etc...
But you have 5 bars in your bargraph...
So before giving you more advice, please define your system, ideally by starting with a reply to Klaus.
Dora.
