Give me IAR EW ARM example for LPC2148 LED blink
milan.rajik
Banned
Give me IAR EW ARM example for LPC2148 LED blinking.
find attachement
  • Lpc214x.zip
I have that file but it doesn't contain LED blinking code.
Code C - [expand]
8
9
10
11
12
13
14
15
int i=8;
main()
  IO0DIR |= 0x0000FF00;   P0.8 to P0.15 as output
   IO0SET |= 0x0000FF00;  P0.8 to P0.15
while(1)
   IO0CLR |=(1<<i);
   Sleep(200);
IO0SET |=(1<<i);
Sleep(200);
@EasyRider
What do you mean by bitbang write only registers ? We are only writing to PORT and not reading them.
I am new to IAR Compiler and LPC MCUs but if somebody help me with an LED example then I will try to master LPC MCU programming in another 3 months.
I tried this but it didn't work. That's why I am asking. http://embeddedcraft.org/iar_arm2.html
When I sad write only I mean that you can only write to this register.
IO0SET |= value equal IO0SET = IO0SET | value - read, modify, write
The correct way is to write directly:
IO0SET = value
Man, you creating few topics per day with the same questions. Last time you crashed one PIC16F877 as I remember. Possible, beter way is to create one common topic like a "teaching Milan how to work with micronontrollers"
Iar, MikroC, PIC, LPC - doesn't matter.
