deboleena18
So i have written the code to generate GMSK signal, but i m not sure if it is correct
it generates a low pass envelope over the PSK signal
Also i wanted to ask if the way i m integrating to obtain phase is correct.
I am doing summation
Please Help Me
okay so instead of normalized time, i decided to use real time equivalent
it is giving me an envelope free gmsk signal. I have a sampling rate of 2000 samples per bit duration ( i need the signal to look analog when i plot it )
anyways , the issue i am facing now is that the signal is clipped at the bottom
that is wrapped phase there are missing values in the range 140 to 180 degrees
this range reduces as i increase sampling rate to 20,000 per symbol
but if it was due to less samples, why did it not affect the positive peak of the signal
any help would be greatly appreciated![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Please Help Me
f_simulation = 20*10; %MHz
fc = 2.4*1000; %MHz
bitrate = 1; %Mbps
bitlength = 10;
Eb = 1; %bitenergy
ep = 0; %receiver side
Ts = 1/f_sampling; %receiver side
BT = 0.5; %for gaussian filter
h_index = 0.5; %MSK modulation index
t = 0:1/f_simulation:bitlength-1/f_simulation; %time us
r = zeros(1,bitlength*f_simulation);
n = zeros(1,bitlength*f_simulation);
b = zeros(1,bitlength);
%b = randi([0,1], [1,bitlength]);
b = [1 1 0 0 1 0 1 0 1 1];
data_signal= zeros(1,bitlength*f_simulation);
k = 1;
for k = 1:bitlength
start_index = (k-1)*f_simulation + 1;
end_index = start_index + f_simulation - 1;
data_signal(start_index:end_index) = 2*b(k) - 1;
end
h = gaussfir(BT, 3,f_simulation); %gaussian pule shaping filter
g = conv(data_signal, h); %g(t) the pulse signal
figure;
plot(g);
t = 1;
int = 0;
phi = zeros(1,bitlength*f_simulation);
s = zeros(1,bitlength*f_simulation);
for t = 1:bitlength*f_simulation
int = int + g(t)*1/f_simulation; %basically integrating upto latest time
phi(t) = 2*pi*fc*t/f_simulation + pi*h_index*int; %phase generation
s(t) = cos(phi(t));
end
figure;
plot(s);
f_simulation = 2e9; %Hz
fc = 2.4e9; %Hz
bitrate = 1e6; %Mbps
bitlength = 5;
bitdur=1/bitrate;
totdur=bitlength*bitdur;%%sec
totsamp=totdur*f_simulation;%%
Eb = 1e-6; %bitenergy
r = zeros(1,totsamp);
n = zeros(1,totsamp);
b = rand(1,bitlength)>0.5; %% little trick
data_signal= zeros(1,totsamp);
%b = [1 1 0 0 1 0 1 0 1 1];%% if u need fix seq
for k = 1:bitlength
start_index = (k-1)*f_simulation*bitdur + 1;
end_index = start_index + f_simulation*bitdur - 1;
end
h = gaussfir(BT, 3,f_simulation*bitdur); %gaussian pulse shaping filter
g = conv(data_signal, h); % final signal
figure(1)
plot(g);
sum = 0;
phi = zeros(1,totsamp);
s = zeros(1,totsamp);
for t = 1:totsamp
sum = sum + g(t+(length(h)-1)/2 )*totdur/totsamp; %basically integrating upto latest time
phi(t) = 2*pi*fc*t*totdur/totsamp + pi*h_index*sum; %phase generation
s(t) = cos(phi(t));
end
figure(2)
plot(s);
