Generating Bipolar Encoded signal using MCU
Amr Wael
Member level 5
Hello ,
I would like to make bipolar encoding using microcontroller STM32 , I have 2 states only 1 and 0 ,
What hardware can be used to generate this signal with the MCU , is there an IC or should I build a circuit ?
Here is a link for the waveforms that I desire to generate
Thank you very much in advance.
my first question is: Why? Aren´t there better/simpler solutions?
With two sates only (one signal) it can´t work. You need at least a second signal. I´d vote for some kind of "clock" signal.
--> USART instead of UART .. for example.
Hardware:
It depends on signal voltages, currents, impedances, frequency / baud_rate ... and so on.
In simplest case you could use an RS232 transmitter IC,
But you could also use other ICs, like flip flops and analog_MUX.
or a circuit based on discretes like transistors.
From the article it appears as though output is determined from your data as well as incoming clock pulses. This brings to mind a D flip-flop whose changes of state are delayed until a clock pulse arrives. JK flip-flop is similar.
Flip-flops have Q and bar-Q outputs. As each is an inversion of the other, you can obtain bipolar AC by connecting a load across them. Can your mcu do the same thing if you program two of its outputs to be at inverted states of each other?
LaTeX Commands Quick-Menu:
