Generate signal smaller than function generator limit
sudil99
Junior Member level 3
I need to generate 0.5 mV to feed to IN-amp. But the minimum voltage my signal generator can generate is 10mV peak-to-peak.
I tried using this voltage divider to get 0.5mV at +ve input, but doesn't work. The output is like 20 times smaller.
How can I get this small voltage?
your ratios are incorrect; they are off by a factor of 10 and also you did 11:1 not 10:1.
output of your voltage divider is Vin * R3 / (R3 + R22) which is:
Vout = Vin * 0.0099 = 0.049mV peak for your 5mV peak input.
assuming you want 1mV p-p output from your 10mV p-p input, you want R3 / (R3 + R22) = 0.1, or rearrange to R22 = 9 * R3
use this tool to find available values: **broken link removed**
so e.g. R22 = 180k, R3 = 20k will work.
p.s. i can't tell exactly what you mean so if you want 0.5mV p-p out then R22 = 19 * R3 and use that tool to find values for that instead.
