vlsi_maniac
Junior Member level 3
hi
i was trying to do gate level simulation using quartus and modelsim.
the dut is a counter and it works at 411 MHz.
now if i write the test bench am i supposed to generate the clock in testbench not more than 411MHz.
and i have seen in sdo file the below para
(CELL
(CELLTYPE "stratix_lcell_register")
(INSTANCE count\[0\]\~reg0.lereg)
(DELAY
(ABSOLUTE
(PORT aclr (4809:4809:4809) (4809:4809:4809))
(PORT clk (2479:2479:2479) (2479:2479:2479))
(IOPATH (posedge clk) regout (156:156:156) (156:156:156))
(IOPATH (posedge aclr) regout (176:176:176) (176:176:176))
what does clk 2479 refers to.
i generated the clock and if the clock is less than 2479 ps(half period) then i am not getting waveforms or the dut is not working.
if reset is less than 4809 ps then dut is not resetting
what does the above indicate.
testbench
module tb_counter ();
reg core_clk;
reg reset_n;
wire [7:0] count;
initial
begin
core_clk <= 1'b1;
forever #2479 core_clk <= ~ core_clk;
end
initial
begin
reset_n <= 1'b0;
repeat(2) @(posedge core_clk);
reset_n <= 1'b1;
end
counter_test counter_u1(
core_clk,
reset_n,
count);
endmodule
please i need this urgently.thanks
(CELL
(DELAY
(ABSOLUTE
testbench
reg core_clk;
reg reset_n;
wire [7:0] count;
initial
begin
core_clk <= 1'b1;
end
initial
begin
reset_n <= 1'b0;
reset_n <= 1'b1;
end
core_clk,
reset_n,
count);
endmodule
