FSK Demodulation (SDR sharp)
NN3694
Newbie level 1
I have a signal recorded by USB dongle (Using SDR sharp). My signal is FSK signal. It is in I and Q format. Can you help me how to demodulate this signal to "0" and "1"? See the picture with my signal.
Thanks for help :)
Jan
The easiest way to do this is to compute the frequency discriminant (i.e. phase difference between consecutive samples). If you plot that, then you should see two clear symbol levels (assuming the signal is fairly clean 2-FSK).
To properly demodulate in an automated manner, you will need to recover the symbol timing and carrier offset. This might be trivial, or might require some simple control loops. If you want any more specific information, please provide your data and I will write some simple Matlab code to demodulate the signal.
