Gandalf_Sr
Member level 1
vk3bhr
I've adapted the front end for this frequency counter (see diagram) from a design byPhil Rice VK3BHR and it works well. Now I want to put in some front end protection for the AT-41533-TR1 emitter follower front end transistor, it's rated at a max of 1.5V Vbe and the 74AC161 is good for a max input frequency of 200 MHz. L1 is supposed to help at high frequencies and its value is 10uH. The I/P and I/P Grnd are connections to a 50 Ohm BNC connector. Pin 15 of the 74AC161 feeds into RA4 of a PIC.
If I fed a 5V 100MHz signal into this circuit it would probably blow the transistor.
Can anyone offer any guidance on how to approach adding protection please?
