Frequency of ramp signal to second order system
garimella
Full Member level 5
I have a system, whose open loop TF is G(s) = (s+1/s)*(1/s)
This is a type2 second order system with Kv=0 and Ka=1 as per the final value theorem.
Kv=0 means the system generates a zero steady state error for a ramp input. My question is what is the max frequency of the ramp input (triangular or sawtooth wave) can I inject to the system ?
In commonly understood form, the transfer function is s²/(1 + s²), a high-pass with infinite Q. Doesn't make sense as technical system, infinite oscillating response on any input. Or is it a typo?
The open loop TF is (s+1)/s^2. Closed loop is (s+1)/(s^2+s+1)
Get an overview in a simulation. Of course you can derive the error analytically as well.
Well from simulation, I found that tracking bandwidth(TB) is typically the region in phase plot where phase lag <= 3 degrees. Beyond this error starts creeping in. My conclusion is TB= cut-off frequency/6. What are your inferred results?
The answer really depends on the acceptable error. A problem with "tracking bandwidth" is that the questioned triangle or sawtooth signals have infinite bandwidth.
