FPGA and DS18B20 sensor reading
esdat35
Newbie level 2
ds18b20 fpga
hi everyone , I want to design a temperature controller circuit by using DS18B20 sensor with spartan 3A DSP FPGA. I read temperature from one sensor but now ı have to read 4 sensor with one-wire bus. Can anyone has a source code and post me ?
thanx for your helps...
is not there anyone help me ?
Hello,
This is a very old subject, but maybe you can answer to my question. I want to connect a DS18B20 temperature sensor to Spartan 3E starter kit but I'm not sure if I should use an external pull-up resistor as mentioned in DS18B20 datasheet for microcontrollers or connect throughly without any resistor. Should I add a pull-up in constraints file?
Thanks....
