yokahu
Newbie level 6
Hi guys,
I want to design a 24Vdc-240Vrms system that will use a Forward Converter (dc-dc) and an H-Bridge Inverter (dc-ac), but I’m confused with the grounds.
The Forward Converter has a transformer in the middle that technically divides the circuit in two, providing different grounds.
So my question is: can I connect the two grounds without affecting the proper function of the Forward Converter?
The reason is that on my design, the ground of the inverter (DC section) has the same ground as the inverter’s control-circuit. But the input voltage of the inverter’s control-circuit will come from the input voltage of my Forward Converter. If that is done, it would be the same as connecting the two ground of the Forward Converter, before and after the transformer.
Thanks for the replies.
