Footprint of FXTH87xx IC
Kick
Full Member level 6
India,Bangalore
hiii all,
I am just stuck with designing of one footprint, Freescale's FXTH87xx IC. Datasheet did not mention about footprint dimension,only IC dimension. Even though I have completed footprint,doubt is there regarding pad dimension. If anyone have this particular footprint,please share me or else give me a suggestion. pdf also attached. Thanks.
  • FXTH871x7.pdf
It looks like a very standard QFN 7x7...
nope...pitch is 1mm. and in package outline which one is pin dimension (0.35mm x 0.15mm or 0.65mm x 0.55mm)???
Please review table 1 and table 3 in the above link.
Datasheet p. 167: QFN, thermally enhanced (exposed ground pad), 7 x 7 x 2.2 mm package, 1.0 mm pitch, 24 pins.
Thanks for all. But I am looking for footprint pad dimension(width is mentioned in shaiko's link,but no length) and also the distance between one side of pads to other side of pads (sorry,I don't know the proper word :razz:).
Pad dimensions are calculated, based on the dimension of the leads and the type of the leads.
IPC has developed a standard for land pattern dimensions. IPC-7351
I am doing land pattern creation for over 10 years now and all the dimensions needed for calculating
the pad dimensions are there.
You can use the free calculator from 'PCB Libraries' to calculate land dimensions, based on the info on the datasheet. It calculates the pads, based on IPC-7351
https://www.pcblibraries.com/
Kick said:
the distance between one side of pads to other side of pads (sorry,I don't know the proper word)
That's called "pad to pad clearance".
