FM radio with TEA5767 and PIC16F877A micro-controller
Hi Jestin_cubetech ,
I just acquired the TEA5767 FM Radio Module, pls share the 16f877a pic source code to test the module.
thanks
circuit:
TEA5676 fm module hex file.
  • TEA5676 fm module.zip
Thanks so much for the hex file. i should have the schematics soldered by tomorrow to test.
Meanwhile can you send the proteus file to see what is expected of the mcu.
I should be done with the hardware hopefully tomorrow, I am currently using 8MHz Crystal Osc. to test.
Please do let me know if its Ok.
Thanks for your response, I will update the crystal accordingly and post updates
I decided to do the simulation of the module following your schematics and there is an error 1.jpg1.jpg 2.jpg
the error message: TEA5767 is not present / not working.
unfortunately TEA5767 model is not available with Proteus.
try with real hardware.
Alright, Thanks.
I am currently working on the hardware, Should be done with it hopefully tonight.
Hi sir am also doing the same project, can u please suggest to me the ways to connect tea5767 to a PCB ? thanks in advance
Hi All,
Can you please kindly share the hex file with me please?
I am interesting in this project.
Thanks,
Nuwan,
Is there any Single chip module for FM transceiver which i can use for long range data transmission?
-Vasu
