Flyback transformer with paralelled secondaries
cupoftea
Our contractor insists on doing our interleave-wound Flyback SMPS transformer (Np/Ns = 12/16) as follows...
S1: 16 turn sec
P1: 12 turn pri
S2: 16 turn sec (S2 in pllel with S1)
This is a bad idea, he would be better off doing it with ...
S1: 8 turns SEC
P1: 12 turns Pri
S2: 8 turns SEC (S2 in series with S1).
This is because if a mistake is made and a 15 turn sec gets accidentally paralleled
with a 16 turn sec, then the 16 turn one will be driving current into the 15 turn piece.
Would you agree, series is always better?
Spec is...
24vin
24out
48Wout
60kHz
Under that scenario yes but I would be concerned if a transformer could be manufactured so badly that turns were missing.
Parallel windings means each only carries half the current compared to series ones.
Indeed - the errors able to be introduced are less with the series approach,
however - if the wire sizes can be all the same - this would be a time saver in manufacturing
also - if you have a low pin count bobbin - paralleling may be useful - only 2 pins needed for pri
We have made very many transformer with paralleled pri and sec wdgs for best performance ( from 50W flybacks to 3kW H bridges ) - only about 1 in 100 have an issue
we return these for properly made ones.
Seriously? And how do you make the design fool-proof against other mistakes?
How about choosing a quality supplier?
LaTeX Commands Quick-Menu:
