Arpit Gupta
Junior Member level 2
I have designed and implemented the flyback transformer using the EE30 FERRITE CORE and the switching frequency is 20kHz, no switcher IC has been used and i am just driving the mosfet irf630 at 20kHz using gate driving IC ir2110 and gaing signals from PIC16F616. The converter was designed to give output voltage of 25V at input of 20V. But the output is only of 5v and the input current at the primary is pretty high about 0.25 amps at input voltage of 25V.
as of now the transformer has no air gap introduced in the design which i believe is the problem for core saturation?
is the core saturation the only problem or is there any other fault in it??
