orangelogic
Junior Member level 1
I am trying to design a FFT block in verilog and I am stuck with the floating-point adder unit. Can anybody help me the rounding logic which involves the usage of sticky bit.
check the output of each stage of ur fft as with stages the decimal point tends to shift and at one point ur results may overflow....orangelogic said:I am trying to design a FFT block in verilog and I am stuck with the floating-point adder unit. Can anybody help me the rounding logic which involves the usage of sticky bit.
