[SOLVED] flashing lpc1768 on the project
ARM developers typically use the JTAG port both program and debug the device, however this method does require a JTAG ARM programmer/debugger.
Two of most popular commercial JTAG ARM programmers/debuggers are:
Segger J-Link
Of course there are open source alternatives and clones available.
The alternative, in the case of NXP LPC ARM variants, is using a UART PORT and the In-System Programming (ISP) bootloader to load and flash the device with the new image.
BigDog
use the following schematic as an easy way for programming(ISP)
