Feco
Newbie level 6
Hello.
I have a finite state machine and I want it to change from state 'idle' to state 'start' when I press a button called 'EN' (rising_edge(EN)). My problem is, it doesn't behave like I wanted. If I press the EN button and keep it pressed, the fsm is going to change the states in every clock cycle, however is shouldn't, only if it detects a rising edge.
So it works like [if EN = '1'] instead of [if rising_edge(EN)], but I have no idea why.
Here is the code:
Thanks.
Here is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity uart is
Port ( CLK : in STD_LOGIC;
EN : in STD_LOGIC;
tx : out STD_LOGIC);
end uart;
architecture Behavioral of uart is
type state is (idle, start, d0, d1, d2, d3, d4, d5, d6, d7, stop);
signal curr_s, next_s : state;
constant data : STD_LOGIC_VECTOR (7 downto 0) := "00111100";
begin
state_proc : process(CLK)
begin
if (rising_edge(CLK)) then
curr_s <= next_s;
end if;
end process;
fsm_proc : process(curr_s, EN)
begin
case curr_s is
when idle => tx <= '1';
if (rising_edge(EN)) then --THAT IS THE PROBLEM
next_s <= start;
else
next_s <= idle;
end if;
when start => tx <= '0';
next_s <= d0;
when d0 => tx <= data(0);
next_s <= d1;
when d1 => tx <= data(1);
next_s <= d2;
when d2 => tx <= data(2);
next_s <= d3;
when d3 => tx <= data(3);
next_s <= d4;
when d4 => tx <= data(4);
next_s <= d5;
when d5 => tx <= data(5);
next_s <= d6;
when d6 => tx <= data(6);
next_s <= d7;
when d7 => tx <= data(7);
next_s <= stop;
when others=> tx <= '1';
next_s <= idle;
end case;
end process;
end Behavioral;
Thanks.
