Finding RC constant of a complex RC circuit
prateek3790
Full Member level 2
finding rc constant of an complex rc circuit
how to find the time constant of a complex circuit, which has many series and parallel components.please see the example circuit below.
can i convert the parallel components to series one using the q value transformation. and now since all are in series the time constant can be Req*Ceq.
Req = R1 + R2
Ceq = c1c2/(c1+c2)
also since i just want to calculate time constant does it matter from where the output is being taken.
Re: finding rc constant of an complex rc circuit
The high-pass low-pass combination has more than one "time constant", actually one zero and a pole pair (two real poles). There's no equivalent Req*Ceq.
        (C1 R2) s
Vo/Vi = -------------------------------------------------
        1 + (C1 R2 + C1 R1 + C2 R2) s + (C2 C1 R1 R2) s^2
... with the assumption that the source_impedance = 0 Ohms and the load_impedance is infinite.
Klaus
        (C1 R2) s
okay.
so among the two poles whichever is smaller that will dominate and will define the overall time constant.
but just for curiosity can you please tell why the above method is wrong. because suppose if it is possible to convert the parallel circuit to series one then in the overall circuit effectively there will be only one cap and one resistor.
The parallel-series conversion is only valid for a single frequency.
To decide about dominant time constant. you need to specify actual RC values. I believe the meaning of "dominant" also changes with the pole/zero sequence.
I want to believe that by mentioning RC time constant the OP is talking about the circuit response to step change as regards DC operation.
