orienteraren
Junior Member level 1
Hi!
I´m experiencing a problem. I´m trying to design a circuit where I want to know the bearing. To know the correct angle (i. e. 227 deg) is not of importance but the deviation from the start angle is (i. e. +13 deg) and I cannot use a magnetosensitive component since this application will be used in environments with high precensce of iron. I was thinking of using a gyroscope and from the output there calculate the deviation but I will only record measurements at about 1 measurements every 15 second and I want to know the deviation in bearing I´ve made during this time. To increase the sample rate woud cause me a great hassle. I´ve been looking for components thet deliveres a bearing deviation but to no avail, does anyone know if such a component exists and where to find it or if there is another solution to this problem that I have not considered?
Thanks in advance
Fredrik
Thanks in advance
Fredrik
