fedora kernel rpmbuild error
Techietone
Junior Member level 3
Hi Guys!
I've completely disturbed directory structure in /usr/src directory and now i'm getting error when i try to rebuild kernel using "rpmbuild" on "kernel-2.6.11-1.1369_FC4.src.rpm".
The error i get is :
/usr/include/asm/errno.h:4:31: error: asm-generic/errno.h: No such file or directory
I'm using 2.6.11-1.1369_FC4. I want to restore the original settings so that modules that require kernel compilatn does not cause problem.
Please help me out.
Sir
I have seen this error before, but I do not remember the source of it. just, it can be solved easily.
so you have now /usr/src/linux directory and your kernel is inside this, yes?
I tried creating the required directories and links.. it did not work. So, finally I reformated the system.
