explain zero padding in OFDM
ifft zero padding dvb-t 1705 2048
Aya2002 said:
Hi communication_engineer,
we are working in the frequency domain not in the time domain so leave the casual and non casual aside.
Yes but we put the cyclic prefix in time domain and not the frequency domain to deal with 1) Avoid losing info in Multi-path and 2) Make sure that we have cyclic convolution in time domain so that in frequency domain we can use simple multiplication, now my point is that both these operations are in time domain and if we copy something from the end (future) to the beginning (present) requires future knowledge of what would be the signal at the end.
I know this works somehow, I mean thats why we have successful implementations so .... how does it happen or more precisely how can it happen
Aya2002 said:
It is possible in code time to do the copy and paste for the end to paste it in the begining of the signal.
I hope my answere is cleare.
What is code time, do we buffer our signal till the end and afterwards copy the end at the beginning?
    Aya2002
ifft zero padding 2048
code time: i mean in the matlab code design time.
now, we wait the signal to be generated by the IFFT block and then we did what we need. so it is no need to deal as a casual or not a casual.
hope it is cleare
zero padding in frequency domain matlab
It is not possible to generate Non-causal signal.
"if we copy something from the end (future) to the beginning (present) requires future knowledge of what would be the signal at the end. "
the signal thet comes at the end is the delayed signal not the future valued signal.
Also, there is always the processing time delay in LTI system. as we know IFFT block(parallel block) is linear processing.(we will using buffer) defintely there will be group and phase delay.
In MATLAB we use array processing. where we compute the whole signal values and only then we do cyclic prefix.
Happy learning.
    Aya2002
make correct zero padding
Hi communication engineer,
I like to add some more point reg use of non-causal signals.
Causality property is not used in applications , in which the indepent variable is not time .
It is often used where procesisng data that are recorded already, especially speech, meteorological , stock market analysis. Here are by no means constrained
to causal processing
Happy Learning
    Aya2002
zero padding in ofdm fft
hi friends,
thank you very much,
I want to start in the digital communicatios. Can i have an advise?
thanks
    Aya2002
cours zero padding ofdm
start learning from the book digital communication by bernaud sklar. which is the best book of all
Happy learning
elementary period in ofdm concept
Hi rramya,
can you tell me more.
Thank you
    Aya2002
zero padding end beginning
Communication Systems
With Solutions Manual supported by Matlab Code
4th Eddition
Modern Analoge And Digital Communications_Systems
by: B. P. Lathi
there are many others. Just decide your direction at first !
