ESP32 Modbus RTU and measuring miliamp current
brunofunchas
Full Member level 3
Portugal
Hi!
Is it possible to use Modbus RTU directlly on the pins of an ESP32? Using arduino framework on VSC. Or should I use a MAX485?
For measuring miliamp current in a 240Vac system can I use ACS712? Is there other option?
Thanks,
Bruno
Hi!
Thanks,
Bruno
you can choose: ACS70331
Here is link to it :
https://www.digikey.com/product-detail/en/allegro-microsystems-llc/ACS70331EESATR-2P5U3/620-1890-1-ND/8120690
These sensor have smaller noise (8ma for 1MHz band), and bigger sensibility. For AC current you have to average a half of period (for sinus curve).
For first question - yes using a Max485 is simpler(and in my opinion better) option.
Thanks,
I'm going to look at it. I will have to hand soldering the PCB so i will look to other type of Package / Case.
