mrnithinmr
Newbie level 2
Here's a sample of the errors and warnings i get when compiling through the "compile hdl simulation libraries" option..
--> Compiling vhdl unisim library
> Unisim compiled to D:\xilinx\ISE\vhdl\mti_se\unisim
> Log file D:\xilinx\ISE\vhdl\mti_se\unisim\cxl_unisim.log generated
> Library mapping successful, setup file(s) modelsim.ini updated
compxlib[unisim]: No error(s), 3 warning(s)
--> Compiling vhdl unimacro library
> unimacro compiled to D:\xilinx\ISE\vhdl\mti_se\unimacro
> Log file D:\xilinx\ISE\vhdl\mti_se\unimacro\cxl_unimacro.log generated
compxlib[unimacro]: No error(s), no warning(s)
--> Compiling vhdl simprim library
> Simprim compiled to D:\xilinx\ISE\vhdl\mti_se\simprim
> Log file D:\xilinx\ISE\vhdl\mti_se\simprim\cxl_simprim.log generated
compxlib[simprim]: No error(s), 989 warning(s)
--> Compiling vhdl XilinxCoreLib library
> XilinxCoreLib compiled to D:\xilinx\ISE\vhdl\mti_se\XilinxCoreLib
> Log file D:\xilinx\ISE\vhdl\mti_se\XilinxCoreLib\cxl_XilinxCoreLib.log generated
compxlib[XilinxCoreLib]: No error(s), 124 warning(s)
MTI => Model Technology ModelSim SE vcom 6.4b Compiler 2008.11 Nov 14 2008
--> Compiling vhdl secureip(secureip) library
> secureip Secure-IPs compiled to D:\xilinx\ISE\vhdl\mti_se\secureip
> Log file D:\xilinx\ISE\vhdl\mti_se\secureip\cxl_secureip.log generated
compxlib[secureip]: No error(s), no warning(s)
--> Compiling vhdl smartmodel(unisim) library
> use -smartmodel_setup switch in case you want to configure
the modelsim.ini for smart model usage (SWIFT Interface)
> Unisim Smart-Models compiled to D:\xilinx\ISE\vhdl\mti_se\unisim
> Log file D:\xilinx\ISE\vhdl\mti_se\unisim\cxl_smartmodel.log generated
compxlib[smartmodel]: No error(s), no warning(s)
--> Compiling vhdl smartmodel(simprim) library
> Simprim Smart-Models compiled to D:\xilinx\ISE\vhdl\mti_se\simprim
> Log file D:\xilinx\ISE\vhdl\mti_se\simprim\cxl_smartmodel.log generated
compxlib[smartmodel]: 14 error(s), 306 warning(s)
Log file (compxlib.log) generated.
Process "Compile HDL Simulation Libraries" failed
