[SOLVED] ERROR(SPMHCS-1): Symbol is missing a refdes.
gghhh
Junior Member level 2
Hello all,
I am trying to draw the pcb foot print of mini usb type b. When I save the symbol it says ERROR(SPMHCS-1): Symbol is missing a refdes.
Can some1 please help me.
Thanx & Regards
Here is the zip file with .dra and an image of the usb mini type b.
schematic_usb.jpgView attachment 123.zip
when you create library you may be forget to give ref des,here i mention,it is not available delete library and create ones again ,
you do not have to delete library in main window select *.dsn file than right click >> edit object propertiee
now in this window in Comp Ref column check the part which does not have any footprint assigned to it and than give it some ref des
Reactions: gghhh
    gghhh
Actually I am getting this error in PCB editor and not in capture. Here is the Screen shot.
And here is the USB which Im trying to draw the PCB foot Print.
You have to add ref label to footprint before saving it, you can find some documents on internet regarding adding ref des in allegro
Reactions: gghhh
    gghhh
Actually you have to add refdes for that footprint.
open the footprint(.dra).
go to layout-labels-refdes and assign refdes in the class and sub class you need it.
please have a look of the attachment.
after that save the symbol(.dra) and try.
