Error Launching ncvlog
neo_anderson
Newbie level 5
ncvlog
Hi all,
I was trying to simulate a verilog-AMS, and make a symbol, but i occured error. (using version: ius_v5.7_qsr1)
ncvlog(64): 05.70-s001: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
ncvlog: *E,AMSN64: Verilog-AMS not supported in 64-bit mode.
I guess the tool is automatically invoking 64bit, where do i locate this file, is there a Environment variable to be set?
My CDS_AUTO_64BITS is set to NONE
Thanks
error, verilog ams, ncvlog
From the linux command line try:
which ncvlog
To see which binary you're running.
ncvlog 32 bit
hi thanks,,,
i guess i found the sollution.
The problem was... All of the versions of IUS's Binary file was pointing to /64Bit directory. and i went through the /32bit directory... the files of ncvlog,nclaunch ...
did not existed. I dont know why? i guess it is some instalation problem.
But I read "ius_v6.11" runs 64bit. so i loged on to a 64bit machine and started working......
But i did not set the environment variable for 64
thanks
