vijith133
Member level 1
I am working on the design of a charging circuit, where i have to increase the transistor width to almost 5000 um for allowing the current to be 500mA, but when i increase the
size of the transistor an error of this sort comes in:
Gmin = 1 pS is large enough to noticeably affect the DC solution.
dV(net43) = 50 MV
Use the `gmin_check' option to eliminate or expand this report.
C2: Initial condition computed for node net0106 is in error by 32.221 mV (1.34254 %).
Decrease `rforce' to reduce error in computed initial conditions. However, setting rforce too small may result in convergence difficulties or in the matrix becoming singular.
if i further increase the size the % error is higher, could any one suggest the solution please. It would be really of great help
dV(net43) = 50 MV
