error in synopsys custom designer in LVS
sandeep_sggs
Full Member level 2
india
dear all,
i have implemented an inverter in synopsys custom designer. and now i am trying to do DRC, LVS and Parasitic extraction. Problem is when i do the DRC check then i could pass it. but when i try to go for LVS, i get errors. can any body tell me whats wrong with my procedure. i am attaching the relevant files.
I using synopsys for the first time
  • synopsys.cshrc.doc
... and I've never used it, so I don't know if my following note will be helpful:
With C@dence LVS tools, the extracted view is called extracted, so in the LVS Setup and Run window in the Layout section, the View type should be extracted, not layout. May be this is similar with your tool?
