hulk789
Junior Member level 3
Can somebody help me out debug the issue of non convergence.
error
Netlist
error
T-Spice - Tanner SPICE
Version 14.11
Network license
Product Release ID: T-Spice Win32 14.11.20090811.05:10:58
Copyright © 1988-2009 Tanner EDA
Parsing "C:\Users\RAJUCH~1\AppData\Local\Temp\Comparator1.sp"
Including "C:\Users\Raju Chaudhari\Documents\Tanner EDA\Tanner Tools v14.1\L-Edit and LVS\LVS\SPR_Core\hp05.md"
Loaded MOSLevel3 model library, SPICE Level 3 MOSFET revision 1.0
General options:
threads = 4
Device and node counts:
MOSFETs - 9 MOSFET geometries - 2
BJTs - 0 JFETs - 0
MESFETs - 0 Diodes - 0
Capacitors - 2 Resistors - 0
Inductors - 0 Mutual inductors - 0
Transmission lines - 0 Coupled transmission lines - 0
Voltage sources - 2 Current sources - 2
VCVS - 0 VCCS - 0
CCVS - 0 CCCS - 0
V-control switch - 0 I-control switch - 0
Macro devices - 0 Verilog-A devices - 0
Subcircuits - 0 Subcircuit instances - 0
Model Definitions - 2 Computed Models - 2
Independent nodes - 7 Boundary nodes - 3
Total nodes - 10
Opening output file "C:\Users\RAJUCH~1\AppData\Local\Temp\Comparator1.out"
Warning : Newton solver has failed due to extremely large node voltages.
: If the circuit has very high gain and extremely large voltages (>1000V) are expected,
: then you may use '.option vmax=0' to disable this check.
Conventional DC operating point computation failed.
Gmin stepping failed
Final gmin value = 1e-006, dcstep = 100
Source stepping failed at 0.00% rampup
Multi-rate source stepping failed at 33.33% rampup due to source inp
Pseudotransient analysis at 0% completion
Pseudotransient analysis failed
Fatal Error : DC operating point non-convergence
Parsing 0.01 seconds
Setup 0.01 seconds
DC operating point 0.64 seconds
Transient Analysis 0.00 seconds
Overhead 9.29 seconds
Total 9.94 seconds
Simulation failed with 1 Warning 1 Fatal Error
********* Simulation Settings - General section *********
********* Simulation Settings - Parameters and SPICE Options *********
*-------- Devices: SPICE.ORDER > 0 --------
CCapacitor_1 Outm Gnd 1p
CCapacitor_2 Outp Gnd 1p
MNMOS_1 N_2 Inp N_1 N_1 NMOS W=2.5u L=600n AS=2.25p PS=6.8u AD=2.25p PD=6.8u
MNMOS_2 N_4 Inm N_1 N_1 NMOS W=2.5u L=600n AS=2.25p PS=6.8u AD=2.25p PD=6.8u
MNMOS_3 N_1 LATP Gnd Gnd NMOS W=2.5u L=600n AS=2.25p PS=6.8u AD=2.25p PD=6.8u
MNMOS_4 Outp Outm N_4 N_4 NMOS W=2.5u L=600n AS=2.25p PS=6.8u AD=2.25p PD=6.8u
MNMOS_5 Outm Outp N_2 N_2 NMOS W=2.5u L=600n AS=2.25p PS=6.8u AD=2.25p PD=6.8u
MPMOS_1 Outm Outp Vdd Vdd PMOS W=7.5u L=600n AS=6.75p PS=16.8u AD=6.75p PD=16.8u
MPMOS_2 Outp Outm Vdd Vdd PMOS W=7.5u L=600n AS=6.75p PS=16.8u AD=6.75p PD=16.8u
MPMOS_3 Outp LATP Vdd Vdd PMOS W=7.5u L=600n AS=6.75p PS=16.8u AD=6.75p PD=16.8u
MPMOS_4 Outm LATP Vdd Vdd PMOS W=7.5u L=600n AS=6.75p PS=16.8u AD=6.75p PD=16.8u
********* Simulation Settings - Analysis section *********
.tran 1n 800n
.include "C:\Users\Raju Chaudhari\Documents\Tanner EDA\Tanner Tools v14.1\L-Edit and LVS\LVS\SPR_Core\hp05.md"
.print tran v(Outp,gnd) v(Outm,gnd) v(LATP,gnd) v(Inp,gnd) v(Inm,gnd)
vdd Vdd gnd DC 5
inp Inp gnd DC 3.0
inm Inm gnd DC 4.0
Vclk LATP gnd DC 0.0
********* Simulation Settings - Additional SPICE commands *********
.end
