yourssincerly
Newbie level 3
I’m doing a project where a device is built to measure the girth of a rubber tree in a rubber plantation.
I need to give an identity to each tree to store the measurements of each tree.
The ID of each tree contains 33bits (in binary). For error detection and correction I’m hoping to encode this 33bit word in to a code word (Using a error control coding technique) and generate a 2D matrix (Color matrix-With red and cyan squares representing 1’s and 0’s). The 2D matrix will represent the coded word. This matrix will be pasted on the trunk of the tree. And a camera (the device) will be used to take the image of the 2D matrix and the code will be decoded then the ID of the tree will be taken.
I’m looking for the best scheme to implement this. I thought of cyclic codes for coding, but since the data word is 33 bits cyclic codes seems to be bit complicated.
Can someone please suggest the best way (at least a good way) to implement this???
Additional info: The image is taken in a forest environment (low light condition), Color matrix is to be used considering the environment.(The bark of the tree is dark so black and white matrix would be not appropriate)
