INS-ANI
Full Member level 3
implementation on DE2 not giving exact results
I am writing a code for generation of various frequency range from 1Mhz to 1 hz from an input 50mhz clk.
The full code is as below.
The code is not giving desired output on DE2 board. The led are not glowing as they should.
Please do mention if you require any other inputs.
Please troubleshoot the same.
Thankyou.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity clk_div_librarymodule is
port (
clock_50mhz : in std_logic;
sw : in std_logic; --sw[0]
clock_1hz: out std_logic;
clock_100khz,
clock_10khz,
clock_1khz,
clock_100hz,
clock_10hz,
clock_1mhz :buffer std_logic;
ledg0,ledg1,ledg2,ledg3,ledg4,ledg5,ledg6 : out std_logic --ledg[7]
end entity clk_div_librarymodule;
architecture a_clk_div_librarymodule of clk_div_librarymodule is
signal D0,D1,D2,D3,D4,D5,D6 :std_logic;
signal count_50mhz,count_1mhz,count_100khz,count_10khz,count_1khz,count_100hz,count_10hz,count_1hz : std_logic_vector(27 downTO 0);
begin
process(clock_50mhz,sw)
begin
if (sw='1') then
count_50mhz<=X"0000000";
D0<='0';
elsif (clock_50mhz'event and clock_50mhz='1') then
count_50mhz<= count_50mhz+1;
if( count_50mhz < X"2FAF080" ) then
ledg0<='1';
D0<= not D0;
elsif (count_50mhz > X"2FAF080") then
if (count_50mhz < X"5F5E0FF") then
ledg0<='0';
else
count_50mhz <=X"0000000";
end if;
end if;
end if;
clock_1hz<=D0;
end process;
begin
if (sw='1') then ------------------------[B][U]<ERROR HERE>[/U][/B]
count_1mhz<=X"0000000";
D1<='0';
count_1mhz<= count_1mhz+1;
if( count_1mhz < X"32" ) then
ledg1<='1';
D1<=NOT D1;
elsif (count_1mhz > X"32") then
if (count_1mhz < X"64") then
ledg1<='0';
else
count_1mhz <=X"0000000";
end if;
end if;
end if;
clock_1mhz<= D1;
end process;
begin
if (sw='1') then
count_100khz<=X"0000000";
D2<='0';
count_100khz<= count_100khz+1;
if( count_100khz < X"1F4" ) then
ledg2<='1';
D2<= NOT D2;
elsif (count_100khz > X"1F4") then
if (count_100khz < X"3E8") then
ledg2<='0';
else
count_100khz <=X"0000000";
end if;
end if;
end if;
clock_100khz<=D2;
end process;
begin
if (sw='1') then
count_10khz<=X"0000000";
D3<='0';
count_10khz<= count_10khz+1;
if( count_10khz < X"1388" ) then
ledg3<='1';
D3<= NOT D3;
elsif (count_10khz > X"1388") then
if (count_10khz < X"2710") then
ledg3<='0';
else
count_10khz <=X"0000000";
end if;
end if;
end if;
clock_10khz<= D3;
end process;
begin
if (sw='1') then
count_1khz<=X"0000000";
D4<='0';
count_1khz<= count_1khz+1;
if( count_1khz < X"C350" ) then
ledg4<='1';
D4<= NOT D4;
elsif (count_1khz > X"C350") then
if (count_1khz < X"186A0") then
ledg4<='0';
else
count_1khz <=X"0000000";
end if;
end if;
end if;
-- clock_1khz<='D4';
end process;
begin
if (sw='1') then
count_100hz<=X"0000000";
D5<='0';
count_100hz<= count_100hz+1;
if( count_100hz < X"7A120" ) then
ledg5<='1';
D5<= NOT D5;
elsif (count_100hz > X"7A120") then
if (count_100hz < X"F4240") then
ledg5<='0';
else
count_100hz <=X"0000000";
end if;
end if;
end if;
clock_100hz<=D5;
end process;
begin
if (sw='1') then
count_10hz<=X"0000000";
D6<='0';
count_10hz<= count_10hz+1;
if( count_10hz < X"4C4B40" ) then
ledg6<='1';
D6<= NOT D6;
elsif (count_10hz > X"4C4B40") then
if (count_10hz < X"989680") then
ledg6<='0';
else
count_10hz <=X"0000000";
end if;
end if;
end if;
clock_10hz<=D6;
end process;
end a_clk_div_librarymodule;
Thankyou.
