Embedded the Neural Network in FPGA
conanct
Newbie level 3
fpga neurone network
Hi all,
I am doing Image Processing using Matlab R14 (SP1). I use Neural Network Toolbox to recognize the object. After that, I want to embed the Neural Network in FPGA because the equipment must be portable. However, I don't know how to do?? I intend to convert from Matlab to VHDL using commercial software or any tools.
If using Accelchip or Xilinx systemgenerator, Could it convert the Neural Network from Matlab to VHDL to embed in FPGA????
Every suggestion is welcome.
I need the help from everyone.
Thank you,
neural network on fpga
Matlab and more specifically Simulink Xilinx Toolbox provides HDL code generation. That means that you have to brake down your neural network to basic primitives (multipliers,adders,etc) model it in Simulink and then convert it to VHDL using the Xilinx Toolbox. It is not possible to use the Neural Network Toolbox and convert it to VHDL, just forget that!. Bare in mind that the generated code is not available to see or edit. So for me it would be better to understand how a neural network works, brake it down, model it in Matlab/Simulink and then code it in VHDL. :!:
