tgq
Full Member level 5
16c745
hi
i've tried an easy-to-use USB solution with OPT 16C745 (samples available
hex file for pic given below
hidcomm with examples
VB sample code with my hex file : USB control for port direction and value (read/write)
Blink led on PORTA.0 (pin2) if timer enabled, LED ON/OFF with button if timer disabled
Dim Buffer() As Byte
ReDim Buffer(6)
PORTA => Buffer(0)
TRISA => Buffer(1)
PORTB => Buffer(2)
TRISB = Buffer(3)
PORTC = > Buffer(4)
TRISC => Buffer(5)
hi
ReDim Buffer(6)
PORTA => Buffer(0)
TRISA => Buffer(1)
PORTB => Buffer(2)
TRISB = Buffer(3)
PORTC = > Buffer(4)
TRISC => Buffer(5)
