T
treez
Hello,
Is it possible to do a DRC whereby it only checks clearance and only for the top layer?
You don't actually need to try.Try turn off the display on the layers you don't want. I never try it, but worth a try.
All signal layers are always examined by the Design Rule Check, no matter if visible or not (DISPLAY command).
