microtronics7
Junior Member level 1
Dear Sir,
I am simulating a multiplier in xilinx ise. i want to find dynamic power and plot it against time and frequency using xpower. But it shows 0 dynamic power. I used a clock to feed the inputs and generated a vcd file by the following codes in test bench;
$dumpfile("vcdfile.VCD");
$dumpvars(0, tb_generator_v.uut);
But often the vcd file shows to be 0 kb. When i use xpower to open it then it shows again to be 0 power.
Pls explain in detail since i am a novice.
Pls help!!!!
Pls help!!!!
