Dual voltage regulator +5V & -5V
NicholasTok
Member level 1
lm7905 input
Hi
I have a small problem with my below schematic because I could not get 5V as I keep getting +2V to -2V.
I am using a +9V battery
If I was to use LM7805 and LM7905 can I use +9V input to get both a + & - 5V output?
I welcome to hear your suggestion
Regard,
Nicholas Tok
lm7905 input range
To use LM7905, you need a negative voltage source. A 555 configured as an inverter can provide a low current negative voltage source.
lm7905 regulator circuit
hi asdfgh888,
after looking into the datesheet of LM7805 and LM7905, in order to generate the + and - 5V my input range is 7V ~ 9V if i was to use a 9V battery. comparing to the circuit i am showing it has an input range from 6V to 9V. unless there is other components which allow a range from 6V ~ 9V
Regards,
Nicholas Tok
How much current do you require at +5 and -5v?
hi oddbudman,
around 1mA
regard,
Nicholas Tok
Added after 1 minutes:
i came across this dual voltage regulator circuit using LM317 & LM337, can anyone help me see what is the input range like?
if it is just 1 mA, why don't you use two zener witha 7660 IC ?
If you have also a RS232 driver, you will find on it the voltages needed, jus put two regulators around it ( for more info see the data sheet of MAX232 from maxim ).
here the link:
You can get + 10 V at pin 2 and -10 V at pin 6; overall you can have directly the + 5 V from the battery with a 7805, and then the - 5 V from a 7905 with the input connected to the 6 pin of MAX 232
Mandi
I have understand that dual voltage regulator LM317 & LM337 the Vin range is Vin - Vout = 5V
Which means in order to get a stable 5V output, my min Vin must be Vin - 5V = 5V
Vin = 10V
so the Vin must be equal or more than 10V to have a stable 5V...
