Dual Power Supply Design
Umair Naveed
Newbie level 6
Hi
Please can anybody post circuit diagram of Dual Power Supply in Proteus, with input voltage of 220V and output voltage as +12V, -12V, 5V.
As early as possible !!!!!!
Thanx in advance
If you're looking for a switching power supply here's a PWM datasheet where you can find an aplication of a ±12 V, 5 V flyback supply. The only problem is that your input is 117 Vac, so you would need to make some small adjustments.
diemilio
  • uc3842_1171.pdf
