Dual complementary 1kHz 50% duty square waves.
O
opampsmoker
We need the title.
We think that the cheapest way is with a UCC28C45 into a NOT gate.
As attached.
Can you think of a cheaper way?
We need the square waves +5v to 0V.
(LTspice and pdf attached)
  • UCC28C45_DUAL COMPY OSC.txt
  • Dual complementary outputs.pdf
Apply 2kHz to a toggle flip-flop (clock-divide-by-2). Outputs Q and Not-Q are dual complementary, 50 percent duty cycle 1kHz.
Reactions: opampsmoker
    O
A CD4047 IC has an RC astable oscillator and a divide frequency by 2 to produce a perfect 50-50 squarewave. It has two squarewave outputs with one of them inverted.
    O
SN or HC or CD4049 or 4069/some hex inverter ring oscillator with 2 resistors and one capacitor. Three not gates for oscillator, another to buffer output from not #2, could use spare two nots to buffer not #3. Vout should be 0.05V and 4.95V. Unbuffered hex inverters are supposed to be best for oscillators. Practice with trimpots to get 1kHz is quickest route.
    O
