Fikadu
Junior Member level 3
I have been using IT TMS30F28335 DSP to for different system controllers . All designed hardware was working good so far. Now, it is to develop a new hardware for different purpose. But , it prompts error when connecting Emulator/debugger/ for which a screenshot is attached herewith. For all hardware we designed so far, we used digital and analog ground for the DSP power supply connections and other electrical components as it is recommended in TMS32028x Design guideline. But , for the recent one, our hardware Engineer changes all to analog ground . could this be a reason for the error? is that mandator to use both analog and digital ground while designing TMS320F28335?
Thank you a lot
Thank you a lot
